Battery draining, phone feels warmer
(Topic created: 05-14-2025 09:30 PM)
LeadStarDude
Cosmic Ray
Legacy S Phones
So does anyone know if it is possible to rollback to One UI 6.1, keep getting security updates for 6.1, and stay with 6.1 until One UI 8 is available?
This battery drain issue is ridiculous. Wasting half a day getting everything reverted back to how I had it setup before the update was bad enough, but this persistent battery drain issue no matter what steps I take to mitigate it is infuriating.
My phone feels warmer, it can't possibly be good for the battery, and I'm getting 2 to 3 hours less run time per charging cycle than I did before the update. Is this going to turn into one of those class action lawsuits where multitudes of people sue for phone batteries degrading/failing faster than they should have?
Sorry for the rant, but... 🤦‍♂️
Mujibar
Honored Contributor
Legacy S Phones
Officially, you can't roll back the update.
See this post for more info on battery drain and things you can try until Samsung rolls out a fix:
https://us.community.samsung.com/t5/Galaxy-S-Phones/Battery-drain-on-One-UI-7/td-p/3220005?src=Share...
LeadStarDude
Cosmic Ray
Legacy S Phones
Thank you for the information. I don't want to risk anything, so I guess I'm just stuck hoping that enough people file official reports about it to Samsung as I did to get something done about it quickly.
meself
Honored Contributor
Legacy S Phones
The changes are big update compared to ui6 i would think fixes are being worked on
Mujibar
Honored Contributor
Legacy S Phones
You're welcome. Samsung is very aware of the battery drain issue and is working on a fix. Unfortunately, it is unknown when they might roll it out.
userNBsgoiCeIU
Cosmic Ray
Legacy S Phones
I was curious do you think the location services is what is causing all the battery draining? I noticed my locations is constantly pining with the icon appearing on the top right by my wifi indicator. I know this maybe one of a bunch of combined reasons for the battery drain. I have changed many of my settings to try and prolong battery but in the end it looks like we will have to wait for Samsung to patch.
LeadStarDude
Cosmic Ray
Legacy S Phones
It was mandatory via AT&T for me. It downloads automatically and allows you to select remind me later, but the first time you reset your phone after it has been downloaded, the update installs automatically.
meself
Honored Contributor
Legacy S Phones
Updates will often auto download at some point
patriciostarr
Black Hole
Legacy S Phones
No, exactly; I have a phone with a pending update since April 2024.
Robin621k
Honored Contributor
Legacy S Phones
Do you have a carrier device ?
