Galaxy S9 battery drain and temperature issue
(Topic created: 03-03-2024 11:37 PM)
missg88
Legacy S Phones
So I have the Galaxy S9 an my battery dies quick also the phone gets HOT what should I do? Or what can I do?
SamsungRyder
Neutron Star
Legacy S Phones
Hello, thanks for reaching out about this. I can see how your S9 getting hot and draining battery can be frustrating and concerning. Whether you're using a phone, tablet, smart watch, or earbuds, all Galaxy devices have a set temperature range, where they operate at their best. While they may feel warm under certain conditions, like charging, this does not affect the device's lifespan or performance. However, if your devices get too warm, it could cause some issues. Use this guide to help keep your devices at their normal operating temperature: https://www.samsung.com/us/support/answer/ANS00076952/
This guide can help with reducing battery drain: https://www.samsung.com/us/support/answer/ANS00078987/
If the tips and steps in the above guides don't help, you can do some basic troubleshooting, such as clearing the device's cache partition. The steps are as follows:
- Power off your device.
- While the device is powered off, simultaneously press and hold the power and volume up buttons.
- Once the Samsung logo appears, release both buttons. Your device should boot into recovery mode.
Using the volume buttons to navigate and the power button to select:
- Navigate to "wipe cache partition" and press power.
- Select yes to confirm.
- Navigate down to "Repair apps" and press power.
Next would be to see if a third-party application is responsible for this behavior, using Safe Mode:
https://www.samsung.com/us/support/answer/ANS00062983/
If it isn't improving behavior while in Safe Mode, it may be time to try a factory reset. Back up all files and data you wish not to lose beforehand: https://www.samsung.com/us/support/answer/ANS00062983/
If the above troubleshooting did not assist in resolving this matter, we would recommend upgrading your product as due to the age of the unit, it would be beyond economical repair.
You can find great deals on all our new Galaxy phones here on our website: http://www.samsung.com/us or feel free to explore your options with Local Retail & Carrier stores.
Legacy S Phones
That phone is kind of outdated The thing that gets it hot is probably the CPU it's recommended to dunk it in cold water for a little bit or just keep it in cold places those tend to get hot I have to Samsung Galaxy S8 just downloading stuff gets it hot but I also have the s23 ultra which I'm using right now
missg88
Legacy S Phones
Ya im thinking of upgrading my phone, cause dang i barley take the phone off the charger an my battery dies an the phone starts to get hot on me
Legacy S Phones
Yeah technically the Samsung Galaxy S9 is no different than the S8 because the only difference is the camera and there's really no differents between the two
Legacy S Phones
Like I said I have the Samsung Galaxy S8 and whenever Ubuntu touch adds the S8 to their compatibility list I am adding the OS
missg88
Legacy S Phones
How do I do that to mine
Legacy S Phones
You can go on the Ubuntu touch website and look out the compatibility list The S9 is not on there yet The only Samsung phone that's on there is the S7
missg88
Legacy S Phones
Dang would i be able to add mine on there?
Legacy S Phones
Soon whenever there is an update on their website through the compatibility list not yet though
missg88
Legacy S Phones
Okay than I shall wait than
