S20 Ultra 5G unlock code I received is 15 characters and not 8?
(Topic created: 08-22-2024 01:18 PM)
artPORp
Legacy S Phones
I have received the network unlock and MCK code for my S20, from AT&T. . However, it is 15 characters long, not 8 like it says I should have gotten. Now what do I? Is there somewhere I can use those codes? Please help, I am so frustrated!!!
realaud
Honored Contributor
Legacy S Phones
You would have to contact AT&T or go into a store and have them unlock it for you.  If they gave you a 15-character code, then the code is 15 characters. You should also have received instructions on how to enter the code.  Don't try to do it if you are unsure, as there are only so many tries, before your phone becomes a brick.  Best to go to a store and let them do it or be walked through it via phone support.
Please mark any response that helped you as your solution.
realaud
Honored Contributor
Legacy S Phones
Denvercity
Legacy S Phones
Shortening the line to 8 wouldn't hurt the update.
meself
Honored Contributor
Legacy S Phones
Can fo it on there site
uservW2QWFzNPJ
Legacy S Phones
You have to remove sim card and put it back in to get the prompt for the code.
