Short cut or icon for Bluetooth connections for exiting paired devices
(Topic created: 08-16-2024 12:30 AM)
flappie
Legacy S Phones
When clicking or tap the Bluetooth connection icon it switches Bluetooth on or off. i don't want to switch off the Bluetooth, just check which device is connecting or not connection because it is connected to my laptop already. I Think there should be an option/shortcut icon to just show your current devices and you can see which is connected or change the connection. i connect to my car, and have 2 different wireless headsets. i currently go to setting,  connections, then Bluetooth and then i can see my connections.
BrรผZZi
Supernova
Legacy S Phones
You can use the quick settings Bluetooth icon.
Just press and hold it.
It'll show you the paired devices menu.
If you want to place a Bluetooth shortcut at home screen I know a way to do it.
BrรผZZi
Supernova
Legacy S Phones
userhS1erdOg1v
Legacy S Phones
Woohoo! I didn't know about this option. Thank you!
winegirl1968
Galaxy
Legacy S Phones
Long press the icon and it should give you a list without turning it off
