Suggestion: add the same edge fade effect (top and bottom) that appears in the app drawer to the quick settings panel
(Topic created: 07-16-2025 06:26 PM)
Jomar_accord
Legacy S Phones
I would like to suggest that Samsung add the same edge fade effect (top and bottom) that appears in the app drawer to the quick settings panel.
When you open the app drawer, the apps near the top and bottom edges fade out softly, which makes the transition look smooth and elegant - there's no hard visual cut.
But in the quick settings panel and Notification panel, that smooth fade is missing. The edge just ends with a hard line or abrupt stop, which looks less polished.
It would be great if the same soft fading at the edges could be used in the quick settings panel and in the Notification panel too, to keep the visual design more consistent across One Ul.
This message was translated from Spanish to English.
NoLuvJavi
Galaxy
Legacy S Phones
Perdon bro, entiendo la mayoria, bo hablo bien en espanol. Pero si trato de ayduar lo mas que yo pueda
NoLuvJavi
Galaxy
Legacy S Phones
Vete a tu Ajustes y luego sigue los fotos 1752716694395.jpg1752716694430.jpg1752716694449.jpg1752716694464.jpg
Jomar_accord
Legacy S Phones
descubri nuevas cosas gracias amigo. Ahora se como hacer mas cosas en mi Samsung.
Perdรณn si no me expliquรฉ bien. No hablaba del blur del fondo como tal, sino del efecto difuminado en los bordes del cajรณn de apps (arriba y abajo). Ese efecto no estรก en los ajustes rรกpidos y panel de notificaciones, y por eso mencionรฉ la diferencia. Perdon๐Ÿ™
NoLuvJavi
Galaxy
Legacy S Phones
Jomar_accord
Legacy S Phones
I have a question, this here is a kind of Samsung Reddit where you talk and ask questions about problems? and another question where is that one suggests things for new things for the operating system from One UI to Samsung?
NoLuvJavi
Galaxy
Legacy S Phones
yes sir.
