27 Monitor with wrong white color and lines around white color
(Topic created: 08-30-2021 01:11 AM)
Zaghal
Monitors and Memory
Hi!
I have two Samsung Monitor G7 Odyssey 27 240Hz and LC27HG70QQMXZN 27 144Hz
Sometimes LC27HG7 show wrong white color and lines around white color
Took the photos using my Camera .
Images below  while watching YouTube video compering it in both monitors .
                   Left photo G7 Odyssey                                               and                                               Right Photo LC27HG7
As you can see the issue in right monitor happens once or twice a week and it is fixed by turning off then on the Monitor.
My question: Is this normal behavior in LC27HG7 model and Is it cover under warranty?
I am afraid things will get worst so what should I do.
SamsungLou
Monitors and Memory
Thank you so much for reaching out! This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: https://www.samsung.com/us/common/visitcountrysite.html.
1 Reply
SamsungLou
Monitors and Memory
