49inch CHG90 Dual Monitor Stand
(Topic created on: 11/10/20 12:51 PM)
usersSmNyjzZWI
Monitors and Memory
Has anyone found a good 49inch CHG90 Dual Monitor Stand?  For two 49".  I can find items all day long for LG but have had no luck with Samsung.
ddaniel51
Comet
Monitors and Memory
When you install the Samsung bracket wall on the monitor it will accept any suitable Vesa 100x100 mount.  Check your manual.
Google " dual vertical vesa mount" and you'll get a number of results.
ddaniel51
Comet
Monitors and Memory
usersSmNyjzZWI
Monitors and Memory
Thank you
