BRACKET WALL missing from monitor box
(Topic created: 09-02-2021 02:03 PM)
userA9OijYSvjc
Monitors and Memory
Hello,
I've been using my LC24FG70QUXEN for a couple of years now and i decided to mount it to a monitor arm. When i removed the plastic backplate i saw that it was not a VESA pattern while the product specifications say it should be. After consulting the manual i was informed that i need another part for this, the " BRACKET WALL" . I have looked inside the box but it is not there. Is it possible to get this part via Samsung? I have found it online but I would prefer to buy it directly from Samsung.
SamsungLou
Monitors and Memory
Thank you for this information! This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link https://www.samsung.com/nl/support, or you can reach out to the Samsung Netherlands Community here https://eu.community.samsung.com/?category.id=nl.
SamsungLou
Monitors and Memory
Good afternoon. I am unable to locate this model number. Was the monitor purchased in the US?
userA9OijYSvjc
Monitors and Memory
No it was bought in the Netherlands (where i live btw). I am sorry i should have started with that.
SamsungLou
Monitors and Memory
