Highlighted
CRG9 USB Power Not enough
JUMP TO SOLUTION
I am using a C49RG90 and macbook pro. The usb charge port out of the monitor is not enough to keep the macbook charged when using it with the display. Is there any software solution to this? Or just have to keep the standard power brick? Thanks
1 SOLUTION
Highlighted
Comet
Re: CRG9 USB Power Not enough
JUMP TO SOLUTION
A USB port will pull out 5 volts, but usually only at 100mA. 500 if you're lucky, but you would need closer to 1A to charge a large device like a macbook.
It will charge it eventually if the macbook is off, but if you want the book running with the monitor, it will have to be with a USB output from an AC outlet.
---My Signature---
If you're anticipating a follow up to one of my posts, please like my post or tag me. I don't generally go back to posts I have replied to unless I get pointed there.
3 REPLIES 3
Highlighted
Comet
JUMP TO SOLUTION
---My Signature---
Highlighted
JUMP TO SOLUTION
Bummer. Thanks for the timely reply though!
I also wonder if through firmware in future Samsung could implement charging through the USB port when the monitor is sleeping.
Highlighted
Galaxy
JUMP TO SOLUTION
The USB 3.0 port on the CRG9 has a maximum power limit of 5v @ 900ma or 4.5 watts.
If the Macbook requires more than this to run/charge then you'll need an external power source.
