Compatible Monitor arm for Samsung Smart Monitor M7 43" (LS43AM702UEXXS)
(Topic created: 10-03-2021 07:36 PM)
userlqL4tbSslK
Monitors and Memory
Hello! I've been searching for a compatible monitor arm/stand that's suitable for my monitor. The issue that I have is that I have a table (140cmx60cm) but the design of the monitor's base makes it too close for comfort.
Has anyone found any solution where the monitor can be positioned like a regular monitor (vertical)? Really appreciate any feedback. Thanks!
1 Reply
ddaniel51
Comet
Monitors and Memory
It appears your M7 is configured to accept a 200x200 Vesa mount.  There are a number of differing vesa mount schemes to choose from.  Google is your friend.
