userq4c9zxmEE3
Is stand base BN63-09008A compatible with S22C300 monitor?
JUMP TO SOLUTION
Hello,
I have a  S22C300 monitor and would like to replace the stand base. Is stand base BN63-09008A compatible with my monitor?
1 SOLUTION
Re: Is stand base BN63-09008A compatible with S22C300 monitor?
JUMP TO SOLUTION
The information below BN63-09008A is not linked to the model number. As previously stated, the model you are inquiring about is not a US model. It would be difficult for me to find information on these parts. If you would like to ensure you locate the stand that is compatible with your monitor, I would recommend calling 1.800.627.4368. They handle inquiries and sales for Samsung products.
6 REPLIES 6
JUMP TO SOLUTION
The BN63-09008A model is not a part we sell in the US, so we wouldn't be able to confirm this.
userq4c9zxmEE3
JUMP TO SOLUTION
Hello,
Thank you for your reply.
This is the BN63-09008A stand I'd like to buy:
On the top sticker I can read there is written BN9621281A, which is the exact original stand base for S22C300 monitor.
Can you please help me find out if it's suitable for me? Please inform who I should ask to in case you are not able to confirm this.
Thanks in advance
JUMP TO SOLUTION
Since this is a 3rd party site and this is the only place I've been able to locate this part. This model is not coming up in our system and more than likely not an authentic Samsung product. I recommend contacting the seller of the product on eBay.
userq4c9zxmEE3
JUMP TO SOLUTION
Hello,
I've just found out that BN63-09008A is not the exact model number. I mean, it is just written on the rear side of both the stand base I'd like to buy and the one I own.
This is the rear side of the stand base on Ebay:
COVER STAND BASE
BN63-09008A
SB350 22 #5-2
BWOF SAMEX
This is the rear side of the stand base I own:
COVER STAND BASE
BN63-09008A
TB300 22 #15-1
BWOF SEH
As you may notice there is a small difference between the two descriptions. Does it mean that they are different models?
userq4c9zxmEE3
JUMP TO SOLUTION
@SamsungDarius could you please reply? Thank you very much
JUMP TO SOLUTION
