userH18J4NqGvK
Missing power supply for Samsung 27" monitor S27B550V Power supply DC 14V 2.46A
JUMP TO SOLUTION
I have a Samsung 27" monitor S27B550V which is inoperable because it is missing the power supply DC 14V 2.46A. Somehow it got lost or misplaced in a move.How does one go about acquiring a replacement unit.
1 SOLUTION
userH18J4NqGvK
Re: Missing power supply for Samsung 27" monitor S27B550V Power supply DC 14V 2.46A
JUMP TO SOLUTION
Thankyou for the information. It's very helpful.
2 REPLIES 2
JUMP TO SOLUTION
You can locate a replacement power supply by visiting samsungparts.com or you can call 1.800.627.4368.
userH18J4NqGvK
JUMP TO SOLUTION
