Monitor arm for a SAMSUNG 28" Odyssey G70A monitor
(Topic created: 4 weeks ago)
uservkoczIPEWF
Monitors and Memory
I bought a Huanuo single monitor mount for the SAMSUNG Odyssey G70A.
But only 2 screws will mount to the back of the monitor !!
As the hookup on the monitor is way smaller then the mounting plate !!
So I need to get another arm to fit all 4 screw mounts..
ddaniel51
Red Giant
Monitors and Memory
The G70A 27 & 32 use the VESA standard 100x100 mount pattern.
The Huanuo mounts I Iooked at incorporate 75x75 and 100x100 patterns on the same mount plate.
What did you buy?
uservkoczIPEWF
Monitors and Memory
The Huanuo HBSS6 model w/75mm X 75mm and the 100mm X100mm on the mounting plate...
Question : If I use only 2 mounting holes, the 75X75 will it be okay ?
Thought it should be all 4 mounting screws for support ?
As a senior citizen over 70, never had a arm setup before !
uservkoczIPEWF
Monitors and Memory
I just found a bracket to use then mount the arm assembly to the monitor.
ddaniel51
Red Giant
Monitors and Memory
The Huanuo and the G70 both have a 4 hole 100mm x 100mm mount pattern.  What is the problem?
