OLED G8 White Point settings bug
(Topic created: a month ago)
oimyounis
Monitors and Memory
TL;DR: On the 34" Odyssey QD-OLED G8 (G85SD) Ultra-WQHD monitor, every time I switch the source and go back the white point settings reset to zero.
There is a bug in this monitor with the White Point settings (I don't know about other settings).
I have two PCs connected to it, one on DP and the other on HDMI. I have the White Point settings adjusted for the HDMI source. Every time I switch to DP and come back to HDMI the White Point settings are reset to zero and I have to readjust them.
This is very annoying and makes using this monitor very frustrating as I change between sources quite often.
It should preserve all settings per source, this way things stay consistent when switching sources.
Tried factory resetting the monitor but got same results so it's a bug in the OS itself.
Please FIX this as soon as possible as I'm thinking of returning it and getting an MSI QD-OLED and just avoid Tizen OS all together!
Model: 34" Odyssey QD-OLED G8 (G85SD) Ultra-WQHD
Firmware: 1313 (latest as of writing this post)
GaryB82
Galactic Samsung Care Ambassador
Monitors and Memory
Since this is a user to user support community you would need to submit feedback in the support tab for help since developers don’t monitor the group.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
ddaniel51
Red Giant
Monitors and Memory
Enjoy your new MSI!
oimyounis
Monitors and Memory
Thank you for taking the time and getting out of your way to wish me that I enjoy it!
I will since it doesn’t have Tizen OS.
