- Mute
ā03-26-2025
10:49 AM
(Last edited
ā04-18-2025
10:56 AM
by
Samsung_Stephan
Hello Everyone,
I can't move my newly purchased Odyssey Ark model monitor down even though I followed all the instructions correctly. There is no problem turning it right or left, but the monitor does not go down. There is a very small movement, then it acts as if it is locked and does not go down.
- Mute
ā03-26-2025 02:32 PM in
Monitors and MemoryHello! Thank you for reaching out! Just want to confirm, are you using the stand that comes with the monitor, or are you using it mounted on a 3rd party desk mount? Also, can I have your full model number to assist further?
- Mute
ā03-27-2025 01:13 AM in
Monitors and MemoryHello. Yes, I use the monitor's own arm. The only problem is that it doesn't go down. It turns and bends everywhere but doesn't go down. model. samsung odyssey ark "ls55cg97wnuxuf" 55inch
- Mute
ā04-17-2025 03:43 PM in
Monitors and MemorySame here, if I rotate it, it just hangs about 2ā from the top and wonāt let me push it any lower.
