Odyssey G8 S32DG802 Auto-Rotation issue - Need access in menu
(Topic created: 12-19-2024 07:53 AM)
ssk0g1
Monitors and Memory
Hi, using this monitor with a Macbook Pro in portrait (vertical) mode has proven impossible, as the built-in auto rotation keeps flipping the image around rendering the portrait mode useless.
Can you please update the firmware so that auto-rotation is possible to turn off in the menu, without having to access the monitor with a service remote as you have to today.
Incredibly annoying and mindboggling that this feature is not possible to deactivate in the menu from factory...!
BR Stephan Skogen
ssk0g1
Monitors and Memory
Solution found:
Use TV menu > Connected Devices > Edit > Edit Device Type: Defaulted to Apple TV; Change to Mac / PC.
Not initially logical, but it works (y)
1 Reply
ssk0g1
Monitors and Memory
Solution found:
