Odyssey G90XF – Wrong Firmware Removed 3D Mode (Need M‑F9037GCZA)
(Topic created: 06-28-2025 02:28 PM)
Kenmaz
Monitors and Memory
Model: Samsung Odyssey G90XF (LS27FG900XNXZA)
Correct Firmware Needed: M‑F9037GCZA‑xxxx.x
Wrong Firmware Received:
- M‑F9027GCZA‑1000.6
- MF9027GCZA‑1004.0[15B1].bin
What’s going wrong:
- “3D Mode” is completely missing from the Game menu after flashing these.
- Reality Hub can no longer detect the monitor.
- Windows recognizes it as a generic display, not G90XF.
What I’ve tried:
- USB formatted FAT32, firmware file at USB root.
- Compatible USB stick (e.g., SanDisk Cruzer Glide 16 GB).
- Connected via DisplayPort 1.4 only.
- Replaced the monitor, reflashed firmware—problem persists.
- Reinstalled Reality Hub v1.0.9 and cleared config files.
What I need:
The proper firmware file starting with M‑F9037GCZA for LS27FG900XNXZA.
- Access to internal Samsung firmware, or a backup copy from another user.
- Help from Samsung devs or Tier 2 support to escalate this case.
This is a $2,000 flagship monitor—I can’t use its core feature due to wrong firmware. 🙏
Thank you in advance!
