Old Samsung T24A350 monitor - HDMI2 is not clear and fuzzy
(Topic created: 11-29-2021 11:42 AM)
userIHKXKOdWDE
Monitors and Memory
I haven't really had a pressing need to use my HDMI2 port until now.  However, when I plug in my laptop (I've tried with both an HP Envy and MacBook Pro) into the HDMI2 source, the text and graphics are not clear and fuzzy.  Interestingly, I don't see these issues when I connect the laptops via HDMI1 so I know it's not a cable issue.
Both HDMI1 and HDMI2 are named to PC as I already know about this issue: https://www.samsung.com/africa_en/support/tv-audio-video/hdmi-pc-connection-text-is-fuzzy-image-is-n... so both the HDMI1 and HDMI2 configurations should be the same.
I've seen a short discussion on reddit as well: https://www.reddit.com/r/Monitors/comments/ekzql5/blurryfuzzy_quality_over_hdmi2_port_but_hdmi1_is/
Does anyone know how to fix this or is this a known issue with these Samsung monitors?
SamsungLou
Monitors and Memory
Thank you so much for reaching out! This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: https://www.samsung.com/us/common/visitcountrysite.html, or contact your regional Samsung Community here: https://r1.community.samsung.com/.
userIHKXKOdWDE
Monitors and Memory
Actually, I don't know why this isn't a US product.  I bought the product in the US and I live in the US.  Perhaps my product was incorrectly registered.  The upper left hand portion of my monitor displays: SyncMaster TA550.
SamsungLou
Monitors and Memory
I apologize, I am having trouble finding this in my system. Can you provide the full model code from the back of the monitor?
userIHKXKOdWDE
Monitors and Memory
Samsung T24A550.  And yes, I bought this a little over ten years ago from Best Buy...
SamsungLou
Monitors and Memory
If a different HDMI cable did no help clear this up, you will need to have the monitor checked by a service technician. I would appear there is an issue with the port switching circuitry.
