Samsung C500 Curved Monitor Ghosting on Dark Images
(Topic created on: 12/10/20 5:10 PM)
userBIc4L8Emka
Monitors and Memory
My Samsung C500 27 inch curved monitor is showing serious ghosting in dark images. I need to know if this is normal or if I need to return the monitor. Is it just the IPS panel or is there something wrong with software/settings/hardware of the monitor itself. see the attached photos - specifically the bottom center. Please help! thank you.ghosting.PNG
SamsungLarry
Monitors and Memory
I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
1 Reply
SamsungLarry
Monitors and Memory
