- Mute
02-10-2021
05:45 AM
(Last edited
08-30-2022
07:30 AM
by
SamsungJecca
) in
Just got my Samsung 27" G5 monitor but it's been doing this weird thing. On start up my right screen will be dimmed and my left normal. Anyone know why this is happening?
Solved! Go to Solution.
- Mute
03-08-2021 07:12 AM in
Monitors and MemoryI recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
- Mute
03-06-2021 12:06 AM in
Monitors and MemoryI have the exact same issue out of the box. I'm using DP, 1.2v. mine will also not wake if the computer goes to sleep. I have to unplug it and restart every time. Tried all sorts of options, latest firmware, etc. Will likely have to get a different monitor. Seems to be a decently common issue after reading the forums. Good luck though.
- Mute
- Mute
03-08-2021 07:13 AM in
Monitors and MemoryAn Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
