- Mute
- Email to a Friend
β01-20-2021 05:06 AM in
Monitors and MemoryGot issues with my Oddessey and the toggle. Recently the toggle won't go down or up in the menu only side to side which means I can't access the menu at all. If I push up and to the side I can sometimes get it to turn off but this is the wrong way round to what it's supposed to be.
Furthermore, when I do get it to switch off when I turn it back on again it generally doesn't remain on on the first attempt it just flashes on with the LEDs then straight off. Second time it might remain on but equally it can just sit there and not do anything, unresponsive and has to be reset at the mains.
I know there was QA issues with these products but I assumed after the firmware fix these went away. Great monitor when it works but this early on in ownership it's not a great experience.
There's also no way to turn off auto-power off on the monitor when the source goes to sleep which is essential for some devices since they keep the monitor turning off and on once asleep.
I'm not prepared to send this away without a valid replacement therefore what is Samsung support doing about this? Seems to be a common problem and all over the forums so please don't just point me to the troubleshooting steps of turning off and on and checking the power is connected...
Solved! Go to Solution.
- Mute
- Email to a Friend
β01-27-2021 04:00 AM in
Monitors and MemoryHave you ensured that the device is fully up to date? If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
Be sure to click " β Accept as Solution" when you find an answer that works for you.
- Mute
- Email to a Friend
β01-27-2021 12:34 AM in
Monitors and MemoryHello,
Anyone at Samsung interested?
- Mute
- Email to a Friend
- Mute
- Email to a Friend
β01-27-2021 04:12 AM in
Monitors and MemoryThanks @SamsungLarry,
The device is on the latest firmware. Seems this boot issue might be capacitor related according to other people which sounds like poor QA. Similarly, the screen jog button works when it's newly turned on but as it gets warmer through use throughout the day it won't do what it's told.
I rely on this for work so I'm reticent to send this off without a replacement.
