userLBJyKh8Xjy
Re: Samsung S27E390H LED Monitor won't turn on
JUMP TO SOLUTION
I've been having the same situation but my monitor is never moved and the blue light indicating that its on doesn't even show, I've boughtan 2 different AV adapters and everytime they worked but the last time, not even 1 week into having the newest A/V adapter, the monitor turned off and now it won't even turn back on.
Black Hole
JUMP TO SOLUTION
Honestly repairs would be recommended. Please send us a private message to http://bit.ly/2CGMMUe with your phone number as well as the model number and serial number of the unit.
usersZPYk3lkZO
JUMP TO SOLUTION
I have the exact same issue.
Black Hole
JUMP TO SOLUTION
Do you have the monitor plugged directly into an outlet?
usergWe6kcqfph
JUMP TO SOLUTION
I have had my monitor one year and am having the exact same issue. It periodically within the first six months started blacking out on and off.  Now it won't display anything at all.  I unplugged it for a night, but it is just black and won't display anything.  It was an expensive  monitor to only last one year.
userGStcxxEaJ8
JUMP TO SOLUTION
Just started to have this problem with mine as well. I plugged it in and the screen lit up in the top left like usual and I turned around to plug the hdmi in for my xbox one and it went all black with no bottom right hand side light by the time I turned around. Almost a year old and this is the first time I've had this problem.
userGStcxxEaJ8
JUMP TO SOLUTION
I have tried the unplugging and replugging back in with no avail. Same as with replugging in somewhere else, I get the same result.
userhrjplKtwy6
JUMP TO SOLUTION
Facing the same issue on my new Samsung curved monitor (27").
Any solution?
user8kom82qlT8
JUMP TO SOLUTION
Sometimes these monitors experience a grounding issue when the display cable is removed suddenly. If it is disconnected from power for about 24 hours all the capacitors drain and the BIOS (for lack of a better term) on the motherboard of the monitor resets when you plug it back in, so it is broken for a day or so, and then seems to magically work!
If it happens repeatedly it will require physical repair, but if its only a time or two you might be ok.
Rosebud_989
JUMP TO SOLUTION
I am having same problem with my monitor and trying to unplug from power source to see if that resolves.  This started the first very cold night here and the monitor was never moved unplugged etc.  Of course i have been trying to debug by unplugging things etc....
