Rosebud_989
Re: Samsung S27E390H LED Monitor won't turn on
JUMP TO SOLUTION
Still will not turn on it just flashes the screen then goes dark.  I cannot even get the menu to display.  How do I fix this?
JUMP TO SOLUTION
Is there any indicator light solid or blinking on the monitor?
Rosebud_989
JUMP TO SOLUTION
solid when I have it connected and my screens are extended to it but cannot see because it is dark.  It flashes on for one second then dissappears.
JUMP TO SOLUTION
Are you trying to power on with nothing connected? If there is a device connected, is it a PC or laptop?
Rosebud_989
JUMP TO SOLUTION
It has been connected and working for quite a while a little over two years.  I have it connected to a docking station for my laptop which is a thinkpad.  Just suddenly it stopped working at all only flashes my extended screen then goes dark.  I have powered it off for an extended amount of time to see if that resets it.  I have attached other monitors to my laptop to make sure it is not the laptop.  The power source is good.  My last test would be the cable I have ordered an HDMI cable to connect that is HDMI on both ends...  Not sure what else to do and not sure how to completely reset it as the menu will not even come up.
JUMP TO SOLUTION
You can test with the new cable but if the symptom is not resolved, it would require service. Keep us posted.
Rosebud_989
JUMP TO SOLUTION
Well I dis test with an alternate cable and that did not resolve.  It was a USB to pin cable.  I have been given another monitor to us I am a developer and I needed it badly as working off of laptop screen does not work well as any developer would know.  I purchased it at Costco and not sure what type of coverage there is for this but it is barely maybe 2 years old.
JUMP TO SOLUTION
I would be happy to investigate that. Can you send the full model and serial number here: https://bit.ly/2mQxylV
amd23
JUMP TO SOLUTION
I'm wondering if you were able to resolve the problem because I am having the same problem with a recently out-of-warranty Saumsung monitor.
