Smart Monitor M5 27 AirPlay text not clear
(Topic created: 11-24-2021 08:27 AM)
userqduGsIvXMg
Monitors and Memory
 I got the Smart Monitor M5 to attach it to my Apple Mac Air using Airplay 2 so I could better see the screen. But when I put, for example, Skype on it in a video conference the text is not clear. What can I do to make the text clear. It’s so fuzzy I can’t read it. The settings on the monitor are only two or three different choices. It used to by that you have to set refresh rate, screen size, etc. What settings should I put in the Samsung monitor? What settings should I put into Airplay.
thanks.
1 Reply
SamsungLou
Monitors and Memory
I will be happy to assist with your Skype issue. Is it only the text that is blurred, or is the video having trouble as well? Do you see this in any programs besides Skype?
