- Mute
- Email to a Friend
β06-27-2022 12:53 PM in
Monitors and MemoryI have connected Smart Monitor M8 to my desktop PC (Windows 11) following the instructions at:
https://www.samsung.com/ca/support/computing/how-to-connect-the-smart-monitor-m80b-dedicated-camera/
I have an HDMI cable and also an USB-C cable connected to the left port of the monitor, both connected to the PC, like instructions say to do.
The PC is recognizing the camera, I can see it plugged as an USB device, but when I try to use it with any app, it does not work.
This is a different issue compared to this other post about the camera, because my PC (like many others) does not have a thunderbolt port.
There is a hacky way to make the camera work, which is using the Multiple View mode from the monitor: for some reason with multiple view, the Usb-C can work with the HDMI.
This is clearly a system bug: hdmi connection should work along with the usb-c for camera as well.
M8 is a new and pricey monitor, I would expect these functions to work properly..
Can we get a fix for this setup please?
- Tags:
- M8
- Mute
- Email to a Friend
β06-27-2022 01:30 PM in
Monitors and Memory
