Summary of Issues with Samsung OLED G8 Odyssey and PS5 (Pro)
(Topic created: 07-27-2025 04:06 PM)
WINSPIRE
Monitors and Memory
Monitor Model: Samsung OLED G8 Odyssey (S34BG85)
Console: PlayStation 5 (PS5 Pro)
Core Problem: Inconsistent image processing and input behavior, particularly concerning motion interpolation (TrueMotion/Picture Clarity) and input lag, after basic interactions like turning off/on or accessing the monitor's OSD.
Detailed Issues:
 * Inconsistent TrueMotion/Picture Clarity Performance after Power Cycle/Reboot:
   * Initial "Cold Start" (after unplugging or long-press remote reboot): The monitor displays a "superb, deep, super smooth picture" with highly effective TrueMotion, creating a desired "pseudo 120 FPS" and "3D-like" "bulging" effect. Input lag is acceptable in this state.
   * After Brief Power Cycle (remote only) or OSD Interaction: If the monitor is simply turned off/on via the remote, or if any button on the remote is pressed (e.g., volume, Home button to access the Smart Hub), the image quality changes. The picture becomes noticeably "less smooth," "less bulging," and the TrueMotion effect appears to be "slightly limited."
   * Simultaneous Input Lag Change: Concurrently with the reduction in TrueMotion effectiveness, the input lag decreases slightly. This suggests the monitor reduces image processing, prioritizing lower latency over the desired smoothness, even when not in Game Mode.
 * "Grey Trail" or "Sheen" Artifact:
   * After the monitor is simply turned off/on via the remote, a noticeable "grey trail" or "sheen" becomes apparent in the image, particularly during motion.
   * This artifact persists despite verifying that both the monitor and the PS5 are correctly set to Full RGB range. It indicates a potential issue with RGB synchronization or gamma/contrast handling after the monitor exits standby mode without a full reset.
 * Monitor Not Retaining Optimal Picture Mode/Settings:
   * The monitor appears to revert to a less optimal processing state after standby or brief OSD interaction, failing to consistently apply the highly desirable picture processing (especially TrueMotion) experienced after a full "cold start."
 * Frustration with User Experience:
   * The user is frustrated by the need to perform a "cold start" (unplugging or long-press remote reboot) every time to achieve the desired picture quality and TrueMotion effectiveness.
   * The monitor's "smart" features and Tizen OS seem to interfere with consistent display performance, leading to a suboptimal and unpredictable user experience for high-end console gaming, contrary to expectations for a premium product.
Conclusion/Impact: These issues significantly detract from the user's intended experience of maximizing visual fidelity and motion smoothness for non-competitive single-player gaming on the PS5 Pro, forcing them into inconvenient workarounds.
