- Mute
a month ago (Last edited a month ago ) in
Monitors and MemoryWas looking for detailed information on installing the included very heavy wall mount for the original Odyssey Ark 55. All I found was a manual for everything else and not mounting instructions.
Solved! Go to Solution.
- Mute
Monitors and MemoryInternet search for wall mounting tutorials. Each type of wall, bare studs, drywall wood studs, drywall metal studs, wood wall, brick wall, masonry wall, concrete wall, requires different mounting hardware and prodedures depending on the design and weight of the mounted assembly and display.
- Mute
