- Mute
4 weeks ago in
Monitors and MemoryHi this is a test post as I keep getting a warning that the message body contains words it does not like even though there are no bad words
Solved! Go to Solution.
- Mute
3 weeks ago in
Monitors and MemoryThe 990 EVO Plus is a PCIE Gen 5 device and can do 7000 MB in a proper Gen 5 system.
Any point in the data stream that can't match Gen 5 will reduce the throughput accordingly.
If you test with a Gen 3 system you will get Gen 3 results. Testing will only reflect the bandwidth the system is designed for not what the SSD is designed for.
Putting 200 mph rated tires on a 60 mph car will not make it go any faster.
- Mute
4 weeks ago in
Monitors and Memory- Mark as New
- Mute
4 weeks ago in
Monitors and MemoryCan I send the post to you? I did send to "moderator" but not sure who it will go to.
- Mute
4 weeks ago in
- Mute
4 weeks ago in
- Mute
4 weeks ago in
- Mute
4 weeks ago in
- Mute
4 weeks ago in
- Mute
4 weeks ago in
- Mute
4 weeks ago in
Monitors and Memory
