- Mute
- Email to a Friend
11-16-2020 11:00 PM in
Note 9When i get a call and i have my earphones connected to my phone, the call will automatically switch to speaker. I'm unable to talk or hear during the call with my wired earphones. I've tried using different earphones but they all have the same issue.
- Mute
- Email to a Friend
12-26-2020 02:41 AM in
Note 9Hi, so I had a different, albeit related, issue with the audio after the newest updates. The only way I was able to fix it (and idk if this works for wired sets but it worked for my Bluetooth headsets) I had to go into Settings > in the search bar type "separate app sound" and you have to manually choose which apps go to which devices, its an extra step but not especially difficult. Since then, I havent had any audio issues! Hope this helps.
