Calls going straight to Voicemail Note 9
(Topic created: 09-19-2018 12:27 PM)
5killabees
Galaxy Note Phones
Is anyone else having troble with calls going straight to voice mail? I have had my sim switched out and it still is happening.
userHmqkCVyz6G
Galaxy Note Phones
This worked perfectly on my wife's Note 9 with T-Mobile.  Go to Call Settings -> More Settings -> Call Forwarding.  Make sure that the first option, "Always forward" shows "Turned off".
SamsungKim1
Supernova
Galaxy Note Phones
Does this occur with the device in safe mode?
user6HA6VwKlSv
Galaxy Note Phones
If they are personal calls then no.  If they are telemarking calls, then yes.  I have seen several articles where telemarketers have used technology to leave ringless voicemails.
5killabees
Galaxy Note Phones
I don't know what you mean safe mode. I just get people texting me saying that they called me and it went to voicemail. I have sat beside someone that called me and my phone did not ring.
SamsungKim1
Supernova
Galaxy Note Phones
To place your device in safe mode -
Restart your device
When the Samsung Logo appears
Press and hold the power button and Volume down button
The words Safe Mode should appear on the screen
usersuAa4hejNH
Galaxy Note Phones
Mine too.  How do I fix it?
user1ibDvjL0Pi
Galaxy Note Phones
I have been having the same issue with my Note 9.  It occurs about one out of 4 calls.  I factory reset my phone, turned off bluetooth, but still have the problem.
RedDragon
Samsung Care Ambassador
Galaxy Note Phones
This maybe due to "s.p.a.m protection call." Try to disabled it on the menu setting in phone app and try if it still happening.
userQsadPrNhzh
Galaxy Note Phones
Yes, I am having the same issue.  Is there a fix? Has anyone experienced a blackout screen when trying to engage multiple features example: taking a phone call and attempting to access photo gallery?
user5V3hQQpE6d
Galaxy Note Phones
a lot of people texting me because my phone takes them straight into voice mail. Any suggestions? I am on T-Mobile
