Silverfireblade
Re: Calls going straight to Voicemail Note 9
JUMP TO SOLUTION
Try Verizon tmobile might suck in your area.
userTkQiJrbSuK
JUMP TO SOLUTION
This is happening for me too frequently and I'm in NZ, so this is a global problem
98 SNAKE EATER
JUMP TO SOLUTION
This is actually one of the reasons why I ordered a new Note 9 to replace my current Note 4 Edge (this and horrible reception during calls)
I really hope this isn’t an issue with the new phone
userTkQiJrbSuK
JUMP TO SOLUTION
If you mean call quality during calls, then its fine so long as it's not between the Samsung and an iPhone as then it's just terrible. Of course that's a known issue that no one seems to talk about.
I do find it depressing that you buy the flagship phone from Samsung and it fails to perform it's most basic function as a phone.
Wicked68
Halo
JUMP TO SOLUTION
Go into Settings in the phone dialer and make sure the option to forward calls to voicemail is not turned on
userTkQiJrbSuK
JUMP TO SOLUTION
It's not any obvious thing like that, there are no settings making this happen, it's a fundamental bug with the note 9.
uservupKGLqFlG
JUMP TO SOLUTION
Perhaps will be fixed w/update
userkwFEJGgdkX
JUMP TO SOLUTION
This has been an ongoing issue for me also. New SIM installed and is not any better. Has anyone contacted Samsung ? I'm going to try and call tech support.
userHmqkCVyz6G
JUMP TO SOLUTION
This worked perfectly on my wife's Note 9 with T-Mobile.  Go to Call Settings -> More Settings -> Call Forwarding.  Make sure that the first option, "Always forward" shows "Turned off".
uservATK3JLKvr
JUMP TO SOLUTION
Worked perfectly for me too...thank you! Seems strange that the default setting is to always call forward
