Calls going straight to Voicemail Note 9
(Topic created: 09-19-2018 12:27 PM)
5killabees
Galaxy Note Phones
Is anyone else having troble with calls going straight to voice mail? I have had my sim switched out and it still is happening.
JUMP TO SOLUTION
uservATK3JLKvr
Galaxy Note Phones
Worked perfectly for me too...thank you! Seems strange that the default setting is to always call forward
usere3LOMWDDug
Galaxy Note Phones
I have tried it, it does not work. Problem continued.
user9aSdmAyaDr
Galaxy Note Phones
The ATT call support app is auto blocking calls that arent link to your contacts . Login to it and disable that feature.
userOObR8UcUJI
Galaxy Note Phones
Go into the phone settings and turn off wifi calling. This must have been enabled on one of their updates. As soon as I turned that off, the problem was solved.
Latty92
Galaxy Note Phones
been having this same problem with my note 9 on tmobile. they keep resetting the network and no change, switch the sim no change. was thinking about getting the note 20 but this has me doubting Samsung. Also whenever I get a text message, the same message repeats multiple times.
