TheRetrokid
How much to replace a battery?
How much does it cost to replace a battery for the Note 9? I don't mean getting a replacement refurbished unit with a battery that's just as bad, but I mean keeping the unit I have and just replacing the battery and getting a brand new one. How much is that?
1 REPLY 1
Re: How much to replace a battery?
I would recommend reaching out to your local certified repair technician for a quote.
You can locate the closest UBREAKIFIX at this link: https://www.ubreakifix.com/locations
I hope this message finds you well!
^SamsungZell
