userFUjifhF3vY
Issue with Wired Fast Charging
Anyone else having issues with fast wired charging? Seems like ever since they announced the Note 10 (not trying to be that guy, but what a coincidence) most of the time I can't use fast charging. Using the same power banks and chargers I've had for months.
8 REPLIES 8
Re: Issue with Wired Fast Charging
Are you using the original chargers that came with your device?
userFUjifhF3vY
At the moment, yes. Sometimes I'll get it the first try,...
At the moment, yes. Sometimes I'll get it the first try, sometimes I have to unplug and plug a few times then other times it will ONLY slow charge so I have to use my wireless charger.
Re: At the moment, yes. Sometimes I'll get it the first try,...
Does this issue occur when using different charging cables?
I would recommend taking the device to a local UBREAKIFIX so they can perform an evaluation on your device.
You can locate the nearest authorized repair center in your area by visiting https://www.ubreakifix.com/locations
Samsung_pHBKFfk
Me too it's the same stuff that came with the phone
userFUjifhF3vY
The issue is consistent among multiple cable manufacturer...
The issue is consistent among multiple cable manufacturers, Samsung included. I actually have visited my nearby ubreakifix before. Should I do that or take it to Verizon first? I have insurance through Verizon.
userolW5r9Wz0e
Ever since the last update my note 9 no longer fast charg...
Ever since the last update my note 9 no longer fast charges, all of a sudden it stopped and I've tried multiple original chargers and still nothing. It only says cable charging and no led showing up.
I messaged a Samsung rep and did multiple troubleshooting methods and still nothing, I ever did a factory reset and still nothing.
Re: Ever since the last update my note 9 no longer fast charg...
I recommend uBreakiFix, as they would be able to access your warranty information and not charge a deductible like many insurance companies do. https://www.samsung.com/us/support/ubreakifix/
userKVJ7ZpmthY
Does not matter the cable, starts as fast charging and a...
Does not matter the cable, starts as fast charging and a second later it turns to regular charging.
