Highlighted
My Samsung Note 9 keeps overheating while charging
I have noticed my Samsung Note 9 gets extremely hot (like you can't hold it while charging).  There is really nothing that I have done differently.  There is no pattern and it occurs with all chargers (wall, auto, charging block).
Any words of wisdom?  It's worrisome!
1 REPLY 1
Highlighted
Re: My Samsung Note 9 keeps overheating while charging
Here are some tips that may help. https://www.samsung.com/us/support/answer/ANS00076952/ If the phone continues to overheat I recommend having it evaluated by a certified technician. https://www.ubreakifix.com/samsung
