Highlighted
My phone won't connect to other devices using Bluetooth
why is my bluetooth device cannot connect to other device?
11 REPLIES 11
Highlighted
Re: My phone won't connect to other devices using Bluetooth
I am having the same issue. I have the Note 20. Has anyone reached out to you. I have tried to connect it to my Bluetooth speaker and my beats. So far no luck.
Highlighted
Hello,
Let's try resetting your network settings on your device. Just a heads up, doing this will delete any previous Bluetooth devices that have been previously paired on that device.
1. From your home screen, swipe down from the top of your screen to open the Notification panel
2. Touch the Settings icon.
Reset network settings 1
3. Swipe to and touch General management.
Reset network settings 2
4. Touch Reset
Reset network settings 3
5. Touch Reset network settings.
Reset network settings 4
6. Touch RESET SETTINGS
Reset network settings 5
7. Again, touch RESET SETTINGS. Once you touch RESET SETTINGS, this action can't be undone.
Reset network settings 6
8. Your Wi-Fi, Bluetooth, and other network settings will be reset, back to factory defaults.
Highlighted
Re: Re: My phone won't connect to other devices using Bluetooth
it doesn't work
Highlighted
 In the Bluetooth menu, are the other devices you are wanting to connect to showing in available devices?
Are you wanting to connect to both at the same time using dual audio?
Highlighted
it is not showing in the available devices
I tried two different bluetooth devices, one at a time....
Highlighted
What type of devices are you trying to connect to?
Are they in pairing mode when trying to connect?
I would recommend trying to connect while in safe mode. You can put your phone into safe mode by following these steps.
Press and hold the power button until power off, restart, and emergency mode show on the screen
Tap and hold on the power off option until it changes to safe mode, then tap on safe mode
The phone will then reboot into safe mode. You will be able to check that it is by a grey transparent box in the bottom left of the screen that says safe mode.
Highlighted
As I have stated....I had "no" issues connecting the same devices (headphones) to my Note 8
Highlighted
safe mode did not help either
Highlighted
Are your devices by any chance connected to another device, when you are trying to pair them with your device?
