Archsplinh
Re: NOTE 9 EDGE LIGHTING DOES NOT WORK WHEN SCREEN IS OFF
JUMP TO SOLUTION
To all,
I also have the same problem with the edge light not working.  It was working fine couple days ago when I bought it last week.
I also have the problem work on Allway on display, it seem doesn't work correctly, I try to double tap on the screen, never work.
This is a US unlock version.
Model number SM-N960U1
Serial number < Hidden >
IMEI < Hidden >
Thanks,
JUMP TO SOLUTION
Thank you for that information. Can you provide me with your baseband version and carrier information as well?
Archsplinh
JUMP TO SOLUTION
Baseband version
N960U1UEU1ARJ5
I have ATT sim card install in my device.
Thanks
Archsplinh
JUMP TO SOLUTION
Hello all,
I just did a reset setting this morning and everything seem to working properly now (for both edge lighting and Allway on display).
Note.. the edge lighting seem to work only with the apps that the phone has suggested (Viber and messages) Gmail didn't work not sure Facebook either.
userbF5IyyqoCZ
JUMP TO SOLUTION
Tuesday November, 27 2018
My edge lighting has not worked since reciept of phone. All combination of settings have been tried and all software is current.
Serial number RF8KA101NAX
Android: 8.1.0
Build number: M1AJQ.N960U1UEU1ARJ5
Baseband version:  N960U1UEU1ARJ5
US version, unlocked. T-Mobile is the carrier.
userZakdkgmPhW
JUMP TO SOLUTION
exact problem I have now
userZakdkgmPhW
JUMP TO SOLUTION
started after last update.... with Textra app. no worky. .. . with Samsung messaging app works perfectly fine.     tried 2 other 3rd party apps and didn't work unless screen was already on. lame
userZakdkgmPhW
JUMP TO SOLUTION
EXACTLY  w/ Textra also.   sooooo annoying
user4SD4McntPc
JUMP TO SOLUTION
I have the edge lighting problem....
Samsung Care Ambassador
JUMP TO SOLUTION
@Purple Peanut @SamsungAl I can confirm this very same problem happened on my S8, S9, and Note 9. It isn't a huge deal, because I don't use edge lighting (maybe I would if it worked as intended) but I just wanted to chime in to say this is a systemic issue that hasn't been quashed.
