Samsung Care Ambassador
Re: NOTE 9 EDGE LIGHTING DOES NOT WORK WHEN SCREEN IS OFF
JUMP TO SOLUTION
@Purple Peanut @SamsungAl I can confirm this very same problem happened on my S8, S9, and Note 9. It isn't a huge deal, because I don't use edge lighting (maybe I would if it worked as intended) but I just wanted to chime in to say this is a systemic issue that hasn't been quashed.
userQpvIG02vz3
JUMP TO SOLUTION
I am in the same boat as you.
Work or not, it is criminal to sell as a feature then not have that feature work.
Thank you, Samsung - Iphone... here I come
useriCzOinPpbE
JUMP TO SOLUTION
SM-N960U
N960USQS1CSE1
T mobile
JUMP TO SOLUTION
@useriCzOinPpbE Thanks for posting this information. We will send this to our product specialist. When we have a solution we make a public thread for everyone to see.
Black02SS
JUMP TO SOLUTION
I have the same problem.
userbevLNB5nJx
JUMP TO SOLUTION
My Note 9 edge lighting doesn't come on whether it's screen is on or off. Who should I report it too ?
userpnehdzlDTv
JUMP TO SOLUTION
I have the same problem!!
JUMP TO SOLUTION
Just to double check, do you have the button switched for, When screen is off lit up?
KwestJones
JUMP TO SOLUTION
I have tried all ways.  Edge lighting works when the screen is on but it does not work when the screen is off. I've tried with the setting set to screen off, when the screen is on and always. Very disappointing.
JUMP TO SOLUTION
Can I get your full model code, baseband version, and carrier information?
