userg3IbBDHBVE
Re: NOTE 9 EDGE LIGHTING DOES NOT WORK WHEN SCREEN IS OFF
JUMP TO SOLUTION
I have the same problem, pretty annoying. Can this be fixed please?
userPaxCxcxDRF
JUMP TO SOLUTION
I also have the same problem. 512 GB Verizon. Samsung Messages is the only app where edge lighting works when screen is off (AOD display).
user J
JUMP TO SOLUTION
I also share this problem. Edge light works when screen is on but not off (aod).
Phone: Note 9 128Gb SM-N960F
Build number: M1AJQ.N960FXXS2ARH6
Baseband: N960FXXU2ARH7
userzRpWPAsNO1
JUMP TO SOLUTION
I am having same problem. Note 9 Verizon US.
Greengoblin734
JUMP TO SOLUTION
New user. I had the same problem but found the SOLUTION.
Settings>Display>Edge screen>Tap EDGE LIGHTING>Tap MANAGE NOTIFICATIONS> Move slider to ON.
Also if you haven't already, download EDGE LIGHTING PLUS from Galaxy App store for more customizable options.
userCCMlLhUhPw
JUMP TO SOLUTION
I just got my phone 1 week ago and I can't get to work for anything I try and yes edge lighting on is on , always, and all apps, and thick so I know I'm not missing it
JUMP TO SOLUTION
Can I get your full model code, baseband version, and carrier information?
KwestJones
JUMP TO SOLUTION
What do u do with that information. I supplied my information several weeks ago and never got a reply or heard anything back
user J
JUMP TO SOLUTION
I noticed with WhatsApp it seems to be that you have to allow setting "show popups" in WhatsApp's notification settings. After this the edge lighting for WhatsApp should work. Of course the tradeoff is those horrible popups when you open the screen but...
DataNotFound
JUMP TO SOLUTION
I bought my Note 9 3 days ago. I've double, triple, and quadruple checked all my settings and my edge lighting does not work either. Everything is updated too, so I'm a bit stumped as to why it's not working
