user1emj0Dicni
Re: NOTE 9 EDGE LIGHTING DOES NOT WORK WHEN SCREEN IS OFF
JUMP TO SOLUTION
THIS WORKS...looks like everyon was testing through WhatsApp..atealst me.
usersn4MmOVW7W
JUMP TO SOLUTION
@Greengoblin734 wrote:
New user. I had the same problem but found the SOLUTION.
Settings>Display>Edge screen>Tap EDGE LIGHTING>Tap MANAGE NOTIFICATIONS> Move slider to ON.
Also if you haven't already, download EDGE LIGHTING PLUS from Galaxy App store for more customizable options.
This worked for me. I had only selected on for my Samsung Messages app along with my Google Messages app with the rest not selected. But your tip worked perfectly. lol
Slaptized
JUMP TO SOLUTION
Good news is, they just released an update for the Samsung messages app in the Galaxy Apps store and it fixed this bug. Trust me, it was driving me crazy not getting pop ups. I woke up one morning and the messages app had an update available. Poof, Edge Lighting started working again.
userZpW1vevZfl
JUMP TO SOLUTION
I own a Note9 and it is up to date with updates.  My issue with Edge Lighting is different and just started, as far as I can tell, in the recent past.  (Today is 4 Nov 2018.)
I have Edge Panels and Edge Lighting _turned off_ and yet I still see the Edge Lighting effect.
If I open Settings abd just click on Display, the Edge Lighting comes on and blinks twice rapidly in succession.
I am at a loss on how to turn this off.  It also flashes on other occassions but I am tried of wasting my time on this.  I wish Samsung would sort this out.
userIhWOC4nnIW
JUMP TO SOLUTION
Myne is similar I need to enable popup notifications for all apps to make it work
Noob
JUMP TO SOLUTION
I have the same problem. Only time edge lighting works when screen is off is for a text message. Doesn't work for Skype or What's App. Only works for what's App if you turn on pop up notifications.
JUMP TO SOLUTION
@Noob Have you tried clearing the cache for the apps in question?
Noob
JUMP TO SOLUTION
Yes
JUMP TO SOLUTION
Can I get your full model code, baseband version, and carrier information?
Noob
JUMP TO SOLUTION
SM-N960U
512 gig 8gig ram
AT&T
N960USQS1ARL2
