Noob
Re: NOTE 9 EDGE LIGHTING DOES NOT WORK WHEN SCREEN IS OFF
JUMP TO SOLUTION
I also tried a factory reset and that was no help.
Noob
JUMP TO SOLUTION
Also, everything worked perfect when I got the phone in November of 2018. Edge lighting worked for what's app without pop up on and Skype.
Noob
JUMP TO SOLUTION
New update 9.0 didn't help either.
SpookyMist
JUMP TO SOLUTION
I'm having this issue as well. Edge lighting works when the screen is in use, but when it's locked and always on display, it doesn't work.
Noob
JUMP TO SOLUTION
My regular text messages work when the screen is off but not on. Skype only works when the screen is on and what's app I have to set it to show pop up for it to work with the screen off. But works when the screen is on without pop up. I can't believe they haven't fixed this issue yet.
Noob
JUMP TO SOLUTION
@SamsungLarry  any luck with finding a solution for my edge lighting since I provided the info you requested 3 weeks ago? A software reset was a suggestion from a Samsung tech employee but the closest Best Buy is 2 hours away and my only other option would be to send it in and be without my phone for 7-11 days. Please respond...also please help lol
Noob
Noob
JUMP TO SOLUTION
I called Samsung and they want me to send my phone in for a software reset. I could have done it at Best Buy but the closest one is a 2 hour drive.
Noob
JUMP TO SOLUTION
Did you change any settings related to the edge lighting or notifications?
Noob
JUMP TO SOLUTION
Has anyone found a solution yet?
SpookyMist
JUMP TO SOLUTION
Still no resolution, very frustrating. And Samsung just ignores the problem.
