userzzDecrFVP0
Cosmic Ray
Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
When I zoom in my camera my phone makes a loud buzzing sound out the top of it. The photo or screen becomes very fuzzy like it's being vibrated.
I searched Google and someone else is complaining of this issue too. I cleared the cache like support suggested but I think this may be a hardware issue.
Any one else have this problem?
1 SOLUTION
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
Thank you for following up, if the issue happens while the phone is in safe mode then repairs are recommended. Could you please send me a private message with your IMEI and full Model number?
382 REPLIES 382
JUMP TO SOLUTION
Is it a mechanical sound like it is coming from the physical phone or a digital sound like it is coming from the speaker?
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
I can't tell. It sound like a vibrate motor is on.
Zineturki
JUMP TO SOLUTION
I have the exact same issue with my old Note 5, it happens when u shake the phone heavily. The sound come from the lenses so they can reach their initial position.
userOohKShoPEO
JUMP TO SOLUTION
Like my phone is literally buzzing. I feel it, and when I close the camera app it stops.
user40B0Bt64IU
JUMP TO SOLUTION
Having the Same Issue with my Note 9, did you get it resolved?
JUMP TO SOLUTION
Hey there @user40B0Bt64IU, Have you tried resetting your settings in your camera app?
user40B0Bt64IU
JUMP TO SOLUTION
Yes I have, problem is still there
useryDzquu8SzR
JUMP TO SOLUTION
mine is a physical sound and vibration in the phone what are the next steps.  I followed the recommendation  of clear data and cache in camera app still no better.
usertqA8baJTNq
JUMP TO SOLUTION
I got this too. Very frustrating, I'm thinking this is a hardware defect. At&t is sending me a replacement but I'm concerned it's only a matter of time before the new one is affected also.
