Hatie123
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
My Note 9 was also fine till I upgraded to One UI. The vibrating doesn't happen every single time I use the zoom feature & it does not happen when I use different camera apps like ProShot. I have noticed as the temperature of the phone goes up, it seems to trigger the zooming vibration more often. Because it is not a constant problem yet & the fact that even with the camera hardware being fixed & people are still having problems, I haven't sent my Note 9 in for warranty repairs. I think there has to be a a connection to the issue & software. If it really was a hardware issue, then I would think any 3rd party app would have the same problem. Hopefully, Samsung can update their Camera app & also add back Pro Video mode.
userRhm8RjH0UQ
JUMP TO SOLUTION
I am also having this issue and I think it got worse the other day. Please help
gabe80million
Cosmic Ray
JUMP TO SOLUTION
It happens on all Notes. It happened not my Note 3 and Note 5. Actually, it just vibrates when opening the camera up in general.
userd6EO4BXrXn
JUMP TO SOLUTION
Could someone confirm this only happens on super bright shooting condition?
Samsung_1iIzwYF
Cosmic Ray
JUMP TO SOLUTION
No
userTIAlQVOUCn
JUMP TO SOLUTION
Ive had this issue too when I use the optical zoom in button (the single pind tree on my phone)
Its a mechanical, I don't think a reset will fix anytihg. Have found a work around though.
Before you activate it, focus on a near object, like the ground. Then hit the optical zoom, tap to focus on the ground, now slowly move your camera up to the subject you want. If it buzzes again redo.
rivrfreak
JUMP TO SOLUTION
Another work around below...
I am on the latest available version available on the Verizon network and still seeing regular issues when trying to zoom in on any camera mode. I am quite confident it is a hardware issues as I found what fixes it, until you zoom back out.
When you feel/hear the camera make that faint buzzing sound and the screen goes wavey as it tries to focus, give it a good forward backward shake. It may take a couple of tries until you get a feel for what I'm explaining but it makes the problem go away everytime.
Because of this, I'm confident the issue is related to hardware (at least in some cases) considering software cannot feel shakes, movement.
I also read in another thread that Samsung has confirmed its hardware and needs to be sent for warranty repair.
userkkYDbK74ZE
JUMP TO SOLUTION
I'm having the same issue as well on my Note 9. Everytime I take a picture with the zoom button, it vibrates and the picture is blurry. It sounds and looks almost as it's trying to focus a lens. It happened once then it didn't happen again for a while but now it happens all the time! I hope this issue gets fixed. This camera is one of my favorite things about this phone. Smiley Sad
JUMP TO SOLUTION
Hey, give this a shot.
Go to Settings > Apps > Show system Apps (click on the 3 vertical dots upper right of screen) >
 Camera > Storage > Clear Data and Clear Cache.
 Restart Phone
usermHXOoyf0fv
JUMP TO SOLUTION
 am ahving this issue and i am was about to try that but when i pressed Clear Data it states that:
"All of this applications data will be deleted permanently. This includes all files, settings, accounts, databases etc"
What exactly is this telling me? IS it going to delete all my pictures and my google and samsung account? I am not sure i like how that reads?
