user9S3fP3OIkY
I have the same issue go to your Carrier or to Samsung to...
JUMP TO SOLUTION
I have the same issue go to your Carrier or to Samsung to send you a replacement phone
usercMyI2DpDqW
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
Thanks for taking my 1300 bucks Samsung.. I just started having this problem and I dont wanna shell out another 150 bucks on repairs and/or have my phone taken apart to lose value and my water resistance.
lagunatiara
JUMP TO SOLUTION
jeezz you are right
... i go tried repair this thing but need to spend more more money..
Hi. There really is not much to say about me, I'm just typical normal girl.
userHugL4tSi6T
JUMP TO SOLUTION
Im having the same problem. Ive reset everything an updated everything an nothing works.
JUMP TO SOLUTION
@userHugL4tSi6T Does this still happen when the phone is in safe mode?
userwSuAE1BJhe
Camera buzzing & blurry using 2X Zoom
JUMP TO SOLUTION
So basically for the past few months, when I try to zoom in on my Galaxy Note9, the camera starts to make a buzzing sound and the image goes all blurry. I've googled this problem and I am certainly not the only one experiencing this.
Re: Camera buzzing & blurry using 2X Zoom
JUMP TO SOLUTION
Can I please have your full model number and IMEI in a private message? Do you experience these symptoms in safe mode or all camera modes?
userg3hrTldLGS
JUMP TO SOLUTION
Help needed..My note 9 is having this similar issues..what should i do..Ur help much appreciated.
userS8qcp2wHPi
I'll +1 one this I have the same issue
JUMP TO SOLUTION
RyanDevon8
I had this issue as well and I was about to report to Sam...
JUMP TO SOLUTION
I had this issue as well and I was about to report to Samsung because I just got the device, but my problem was I had like smears on the lens and also if you have a case like a LifeProof for example that covers the lens this will happen. I took my phone out of the case and wiped the lense and it was good to go👍👍👍
