userbYe6clX2jw
Cosmic Ray
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
That's what I'm going to do right now. Ship back this defective phone to Samsung for a credit of $550!
user78sAxLLH9E
JUMP TO SOLUTION
Haha. Apple has more problems with their phones than this.  I'm having the issue and I'm sure it's a software thing.  Never happened until lastest update.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
If it's software related then why does it get fixed when the camera module is replaced? Atleast for a little bit
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
Lepa79
Cosmic Ray
JUMP TO SOLUTION
Some part of the camera module hardware gets lose or displaced under some certain vibrations and with use. Once that happen, it fails to respond properly for the software that is driving things. It is why this issue happen is none existing fresh out of the box.
I ride a motorcycle, and mount the phone in the handle bar.  Had to replace the phone 1st time and module on the 2nd phone. Then sold it because I really believe the note 9 camera module can not withstand vibrations.
Many of the folks reporting the issue here start seeing it after their phone witnessed a normal drop in a protective case. I would assume the vibration from the dropped caused the camera module parts to shift or losen up, resulting in the issue being reported here.
This is my assessment and I am done from messing around with Note 9 since Samsung not recognizing there is a serious problem with the camera module under vibration. I mounted my note 8 on the same bike at the same location for a full year and never an issue. Now I am using Pixel 2 XL. Good luck all.
userTFdrOeRfoc
JUMP TO SOLUTION
I think you're right.   This is terrible.   I can't rely on the phone camera when I need it.   Samsung needs to make this right
usert2dy1E0M3F
JUMP TO SOLUTION
I will need to submit my info as well.
userPAwN38yKIK
JUMP TO SOLUTION
Is there a fix??
userQlS9gCX35r
JUMP TO SOLUTION
Hello sir sure i can give u mine
userdNE14kCxXb
JUMP TO SOLUTION
There are a lot of people with the same problem and Samsung doesn't say anything. What a disappointment.
