Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
Thank you for following up, if the issue happens while the phone is in safe mode then repairs are recommended. Could you please send me a private message with your IMEI and full Model number?
userOJozEFf8aB
JUMP TO SOLUTION
try to put the phone into horizontal mode then zoom, and then raise your phone to disered position. That's the problem i have also.
userxk1pZhabNw
JUMP TO SOLUTION
Facing same issue, when usi g camera in live focus mode...
It's annoying.
JUMP TO SOLUTION
Can I please have your full model number and IMEI in a private message?
userMHnzH8MvAJ
JUMP TO SOLUTION
I m having the same issue with my phone...
userCCAB48tAkq
JUMP TO SOLUTION
I also have a issue with my  Note 9 Buzzing sound when Zooming Camera
usereIyFiuvry6
JUMP TO SOLUTION
I also have this issue
user6SbSFU1y7p
JUMP TO SOLUTION
I am also having these issue what should I do.
userkNt6llZgrz
JUMP TO SOLUTION
I'm having the same issue. It seems like the lens can't get to its desired position and keeps vibrating until you tap screen to focus. It's not like typical vibration motor vibration. On my note 9 it's very subtle to feel but camera goes crazy when I zoom in. It feels like hardware issue. And the vibration only comes from top right corner of the phone.
JUMP TO SOLUTION
Hello @userkNt6llZgrz, I understand this can be very frustrating for you. Can you provide me your full model number and IMEI in a private message here?
