usercJS4yNcmkp
Re: Camera buzzing & blurry using 2X Zoom
JUMP TO SOLUTION
Got this issue too!
I was going to go through the warranty as I assumed the camera module had gone faulty.
If I switch to 2x zoom, the picture flickers and the buzzing camera vibrates the whole device.
If I shake it while it's doing it, it'll stop and I can use the camera normally.
usertmiOqteF9f
Ive had the same issue with my note 9 too and have had 3...
JUMP TO SOLUTION
Ive had the same issue with my note 9 too and have had 3 different cases still the same issue, annoying when trying to capture a quick moment for sure
JUMP TO SOLUTION
JUMP TO SOLUTION
Can I please have your full model number and IMEI in a private message? Do you experience these symptoms in safe mode or all camera modes?
tisfortech
I'm having the exact same issue.
JUMP TO SOLUTION
useruNT8lsb2tP
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
I have same problem, Galaxy Note9 buzzing sound when Zoom
very expensive mobile with problems!
what should i do?
JUMP TO SOLUTION
Just follow the steps in the accepted solution and we'll be happy to help. Smiley Happy
userw2W4CwK0b5
JUMP TO SOLUTION
Hello There, I am having same issue, what should i do? Please help
userhXDLGxjR5X
JUMP TO SOLUTION
Cole, I'm having the exact same issue. I just sent you my phone info? Can you please help? It is really disappointing. I have to use my wife's iphone during our recent vacation.
userhXDLGxjR5X
JUMP TO SOLUTION
I sent out several emails to ask for the steps to send the device back to Samsung but no response. Very disappointed.
