user2OETa8usRq
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
It's not using the telephoto lens though. Try blocking the telephoto lens when zoomed in in pro and you won't see it blocked cause its using the main camera. When repeating this in auto i can see my finger blocking the telephoto lens which it then switches to the main camera automatically.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
Only the main camera lens does anything on my phone. If I cover the 2nd lens it doesn't do anything. Strange
user2OETa8usRq
JUMP TO SOLUTION
Try it in a bright environment
userkXJ3CQKeRp
JUMP TO SOLUTION
Go to Setting-App-3 dot on top right - choose-reset app preferences.
should be working well.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
That actually fixed it for a minute. Then it goes back to vibrating.
userkXJ3CQKeRp
JUMP TO SOLUTION
Yes, agreed. I contacted Samsung again and they asked me to try on Safe Mode. Tried and same issue persist. Lastly, they asked me to refer to the nearest Samsung Authorized Service Centre. Arrggg!
userADyckWICdF
JUMP TO SOLUTION
Have the same issue, tried everthing that support asked me, and nothing works. I bought this phone on a trip to the us, im from chile, and now ask me to send the phone overthere. Im very dissapointed on the brand and their ability to works issues. Had a acer computer that could be sent here on chile for warranty that i bought in the us.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
That's terrible! I'm disappointed in Samsung.  Apple would send you a replacement phone and you could mail the broken one back. I just don't like iOS. I know if I just buy another one it's going to happen again eventually. I can't wipe my phone and send for repairs. My whole work and life is on my phone. This is a problem with no permanent fix
useroLO8ysKuT8
JUMP TO SOLUTION
I'm sorry to hear that. Samsung is really letting everybody down.
userVrKIAC5ok1
JUMP TO SOLUTION
Hola me gustaria saber que solucion tuviste yo locompre en usa y ahora estoy en españa y me dicen que igual se los envie. No se que hacer
