userAX3NdCwc8O
Re: Note 9 Buzzing sound when Zooming Camera
JUMP TO SOLUTION
Hi
I have the same issue in auto mode . Do you still have the issue?
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
Same issue. It's definitely a hardware issue. I'm sending mine in for repair. Once it comes back im selling it.Another user said he got his fixed and it just started doing the same thing a week later. This is major and I can't believe it's happening on a flagship phone they charge you over $1000 for.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
useriRBKRvI9zM
JUMP TO SOLUTION
Because in pro mode you use 1.st middle front camera and it doesn't work with left side camera which buzzing and vibrate.
Espenp
JUMP TO SOLUTION
I Have  the exact same problem as you. I dont know what to do. The the camera is blurry and makes sounds from the lens. This is while you use X2 zoom and also live focus mode. I hope it is a software problem not a hardware. Don't want to send in my phone..
@userzzDecrFVP0 wrote:
When I zoom in my camera my phone makes a loud buzzing sound out the top of it. The photo or screen becomes very fuzzy like it's being vibrated.
I searched Google and someone else is complaining of this issue too. I cleared the cache like support suggested but I think this may be a hardware issue.
Any one else have this problem?
JUMP TO SOLUTION
To anyone experiencing this, can I have your full model code and IMEI number via private message?
userPOAHSk9P9H
JUMP TO SOLUTION
I have same problem..
X2 cam have mechanical sound and no focus...
My note9 have 512 gb. Im from Turkey.
userzzDecrFVP0
Cosmic Ray
JUMP TO SOLUTION
Im so bummed. I don't want to take my phone to a repair center. Just so they can break the seal on my water resistant phone. And fix it temporarily.
We may need to start a class action lawsuit to get this issue resolved
vipeboy2000
JUMP TO SOLUTION
I am also having this issue, it has started after the most recent update. 70% of the time when i go to 2x mode, the phone vibrates and the screen is blurry/wavy. Like the ois or aperature going wierd. Very annoying and frustrating when trying to snap a quick photo and unable to.
userQbSvSxH0dC
JUMP TO SOLUTION
I sent you my details via private message. This issue is really frustrating on a brand new phone.
