user71e1ySEUZs
Note 9 Live focus and zoom blurry and buzzing noise
I noticed my note 9 live focus and zoom to be blurry and buzzing while recording a video. I noticed this to be a manufacturer issue and is consistent with other complaints as well. Please help fix this as i am unable to take any photos in live focus or zoom.
4 REPLIES 4
Re: Note 9 Live focus and zoom blurry and buzzing noise
Thank you for reaching out. Do you experience these symptoms if you test your device in safe mode? Do you experience these symptoms in all camera modes?
user71e1ySEUZs
Yea i definitely hear the buzzing sound even when in safe mode. While the blurry lines are on and off the buzzing sound seems constant.
Hey there!
I would be happy to look into your concerns.
Can you please send me a private message with the below information here at this link: http://bit.ly/2GH8URL
Model code:
(15)Digit IMEI Number:
Samsung_NADdPj0
I am going through the same exact thing... I thought It was a small litch..but now is constant
